查看: 236|回复: 0
CDCLVP1212评估模块
  • 签到天数: 361 天
    发表于 2014-3-24 16:02:24 | 显示全部楼层 |阅读模式
    CDCLVP1212评估模块(EVM)被设计来演示CDCLVP1212的电性能。DescriptionThe CDCLVP1212 is a high-performance, low additive phase noise clock buffer. It has two universal input buffers that support either single-ended or differential clock inputs, selectable through a control pin. The device also features on-chip bias generators that can provide the LVPECL common-mode voltage to the device inputs. This evaluation module (EVM) is designed to demonstrate the electrical performance of the CDCLVP1212. This fully assembled and factory-tested evaluation board allows complete validation of the CDCLVP1212 device functionalities. For optimum performance, the board is equipped with 50-ohm SMA connectors and well-controlled, 50-ohm impedance microstrip transmission lines. Features
    • Easy-to-use evaluation board to fan out low phase noise clocks
    • Easy device setup
    • Fast configuration
    • Control pins configurable through jumpers
    • Board powered at +2.5-V/+3.3-V
    • Single-ended or differential input clocks
    • CDCLVP1212 supports 12 LVPECL outputs; CDCLVP1212EVM supports four LVPECL outputs
    CDCLVP1212.pdf
    927.78 KB, 下载次数: 0
    CDCLVP1212EVM Guide.pdf
    574.68 KB, 下载次数: 0
    GMT+8, 2025-1-15 21:37 , Processed in 0.120683 second(s), 16 queries , MemCache On.
