查看: 272|回复: 0
CDCEL925性能评估模块
  • 签到天数: 361 天
    发表于 2014-3-24 15:57:04 | 显示全部楼层 |阅读模式
    CDCEl925PERF - 评估模块将帮助核实CDCEL925与晶体的选项和1.8 V LVCMOS输入的功能和性能。输出可以通过SMA电缆连接到示波器直接。DescriptionThe CDCEl925PERF-Evaluation Module will help to verify the functionality and performance of CDCEL925 with the options of crystal and 1.8 V LVCMOS inputs. The outputs can be connected to the Oscilloscope directly with SMA cables. The below information/items can be included: The EVM use's guide: SCAU022; the Programming Software Clock Pro: SCAC073.zip; CDCE(L)925 Datasheet: SCAS847Features
    • Easy-to-use evaluation module for fast prototyping and application evaluation.
    • Supporting the entire clock family.
    • Easy and fast device programming through TI Pro-ClockT software.
    • Evaluation of multiple crystals and reference clocks due to flexible input structure.
    • EVM completely USB powered in factory default. Option for USB power and external power supply.
    CDCE925, CDCEL925.pdf
    706.52 KB, 下载次数: 0
    CDCE(L)9xx Performance EVM Guide.pdf
    1.31 MB, 下载次数: 0
    GMT+8, 2025-1-15 22:09 , Processed in 0.113138 second(s), 16 queries , MemCache On.
