查看: 325|回复: 0
CDCE925性能评估模块
  • 签到天数: 361 天
    发表于 2014-3-24 15:36:14 | 显示全部楼层 |阅读模式
    CDCE925Perf - 评估模块允许的功能,CDCE925和CDCEL925的性能与晶体的选项和1.8 V LVCMOS输入验证。输出可以通过SMA电缆连接到示波器直接。DescriptionThe CDCE925Perf-Evaluation Module allows the verification of the functionality and performance of CDCE925 and CDCEL925 with the options of crystal and 1.8 V LVCMOS inputs. The outputs can be connected to the Oscilloscope directly with SMA cables. Features
    • Easy-to-use evaluation module for fast prototyping and application evaluation
    • Easy and fast device programming through TI Pro-Clock software
    • Evaluation of multiple crystals and reference clocks due to flexible input structure
    • EVM completely USB powered in factory default
    • Option for USB power and external power supply
    CDCE925, CDCEL925.pdf
    706.52 KB, 下载次数: 0
    CDCE(L)9xx Performance EVM Guide.pdf
    1.31 MB, 下载次数: 0
    GMT+8, 2025-1-15 22:00 , Processed in 0.112365 second(s), 16 queries , MemCache On.
