查看: 369|回复: 0
SRC4392评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-24 15:30:57 | 显示全部楼层 |阅读模式
    SRC4392EVM-PDK提供了用于评估德州仪器SRC4392设备的功能和性能的模块化解决方案。的PDK包括一个主板(DAIMB)和子板(SRC4392EVM)。DescriptionThe SRC4392EVM-PDK provides a modular solution for evaluating the function and performance of the SRC4392 device from Texas Instruments. The PDK includes a motherboard (DAIMB) and a daughterboard (SRC4392EVM). These boards are plugged into each other to allow a complete solution for analysis of the SRC4392 device using a desk top computer. The modular design allows for common functions to be integrated onto the DAIMB motherboard, while device-specific functions are integrated onto the daughterboard EVM. Features
    • Buffered headers support up to four audio and serial interfaces, compatible with I2S™ style or TDM data formats
    • Flexible reference and master clock generation are supported, using either onboard oscillators or external clock sources
    • Onboard linear regulators derive +1.8 V, +3.3 V, and +5 V power supplies from external supplies or the USB port
    • Power maybe provided from a wall adapter (included) or a +5 V power supply
    • LED indicators are provided for DIR Lock and SRC Ready output flags
    SRC4392.pdf
    1.74 MB, 下载次数: 0
    GMT+8, 2025-1-15 21:49 , Processed in 0.105898 second(s), 16 queries , MemCache On.
