查看: 278|回复: 0
CDCE906/706评估模块
  • 签到天数: 361 天
    发表于 2014-3-24 15:25:22 | 显示全部楼层 |阅读模式
    CDCE906/CDCE706性能评估模块,该器件焊接在电路板上,支持性能测量。该器件预编程(默认设置),但可以通过并行端口进行重新编程,以满足客户的应用。还有另一种EVM与插座,可用于样品编程的目的。The CDCE906/CDCE706 performance evaluation module and provides guidelines to build a customer's own systems. The device is soldered on the board to support performance measurements. The device is preprogrammed (Default Setting), but can be reprogrammed via the parallel port to meet the customer application. There is another EVM with socket available for the purpose of sample programming. The list below shows the four devices, which can be evaluated with the CDCE906/CDCE706 Performance Evaluation Module.
    CDCE706.pdf
    1.34 MB, 下载次数: 0
    CDCE906.pdf
    1.41 MB, 下载次数: 0
    CDCE906/706PERFEVM User Guide.pdf
    869.83 KB, 下载次数: 0
    GMT+8, 2025-1-15 21:36 , Processed in 0.118769 second(s), 16 queries , MemCache On.
