查看: 810|回复: 0
打印 上一主题 下一主题
CDCLVP2102评估模块
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-3-21 17:36:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    CDCLVP2102是一款高性能,低附加相位噪声时钟缓冲器。DescriptionThe CDCLVP2102 is a high-performance, low additive phase noise clock buffer. It has two universal input buffers that support either single-ended or differential clock inputs, and each input feeds a bank of two LVPECL outputs. The device also features on-chip bias generators that can provide the LVPECL common-mode voltage to the device inputs. This evaluation module (EVM) is designed to demonstrate the electrical performance of the CDCLVP2102. This fully assembled and factory-tested evaluation board allows complete validation of the CDCLVP2102 device functionalities. For optimum performance, the board is equipped with 50-W SMA connectors and well-controlled, 50-W impedance microstrip transmission lines. Features
    • Easy-to-use evaluation board to fan out low phase noise clocks
    • Easy device setup
    • Fast configuration
    • Control pins configurable through jumpers
    • Board powered at +2.5-/+3.3-V
    • Single-ended or differential input clocks
    • CDCLVP2102 supports four LVPECL outputs; CDCLVP2102EVM supports two LVPECL outputs
    CDCLVP2102.pdf
    921.31 KB, 下载次数: 0
    CDCLVP2102EVM User Guide.pdf
    433.54 KB, 下载次数: 0
    举报
    站长推荐上一条 4/4 下一条
    【预约参会三重礼】2025 瑞萨电子工业以太网技术日
    查看 »
    GMT+8, 2025-3-23 18:42 , Processed in 0.114899 second(s), 18 queries , MemCache On.
