查看: 253|回复: 0
DEM-DIR9001EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-21 15:36:24 | 显示全部楼层 |阅读模式
    DEM-DIR9001是一个评估板的低抖动,数字音频接口接收器DIR9001。它是由一个单一的+3.3 V电源或+5 V电源工作。DescriptionThe DEM-DIR9001 is an evaluation board for the low jitter, Digital Audio Interface Receiver DIR9001. It isoperated by either a single +3.3 V power supply, or a +5 V power supply.The DEM-DIR9001 has both an Optical Toslink input and a Coaxial input for the SPDIF interface which can achieve standard digital audio interface format IEC60958, AES/EBU, and JEIAT CPR-1205 (formerEIAJ CP-1201, 340).The DEM-DIR9001 recovers standard system clock and PCM audio interface clock from incoming biphasesignals such as SPDIF, IEC60958, and AES/EBU. These signals are provided to the audio DAC/DSP, buffer output, and direct output. Features
    • One-Chip Digital Audio Interface Receiver (DIR) Including Low-Jitter Clock-Recovery
    • Compliant With Digital Audio Interface Standards: IEC60958 (former IEC958), JEITA CPR-1205 (former EIAJ CP-1201, CP-340), AES3, EBU tech3250
    • Clock Recovery and Data Decode From Biphase Input Signal, Generally Called S/PDIF,EIAJ CP-1201, IEC60958, AES/EBU
    • Biphase Input Signal Sampling Frequency (fS)
    • Range: 28 kHz to 108 kHz
    • Low-Jitter Recovered System Clock: 50 ps
    • Jitter Tolerance Compliant With IEC60958-3
    • Selectable Recovered System Clock: 128 fS, 256 fS, 384 fS, 512 fS
    • Serial Audio Data Output Formats: 24-Bit I²S;
    • MSB-First, 24-Bit Left-Justified; MSB-First 16-, 24-Bit Right-Justified which User Data, Channel-Status Data Outputs Synchronized With Decoded Serial Audio Data
    DIR9001.pdf
    679.55 KB, 下载次数: 0
    DIR9001 Eval Board Guide.pdf
    471.31 KB, 下载次数: 0
    GMT+8, 2025-1-15 21:34 , Processed in 0.112895 second(s), 16 queries , MemCache On.
