查看: 202|回复: 0
DRV8825评估模块
  • 签到天数: 361 天
    发表于 2014-3-21 13:58:58 | 显示全部楼层 |阅读模式
    DRV8825评估模块包含一个2.5A,片上索引器的双H桥电机驱动(脉冲/方向控制接口),支持多达32个微步,而且可以用来驱动一个双极步进少量的外部元件电机。DescriptionThe DRV8825 evaluation module consists of a 2.5A, dual-H-bridge motor driver with on chip indexer (step/dir control interface) supporting up to 32 micro steps and a small number external components that can be used to drive a single bipolar stepper motor. The on-board MSP430 MCU + software/GUI provides signaling and control. With the DRV8825EVM, designers can quickly and easily evaluate the performance of DRV8825 motor driver in their specific application.Features
    • 2.5A Peak / 1.75A RMS Current Output per Bridge
    • Wide Operating Voltage: 8.2 to 45V
    • Low RDSON (400mR LS+HS)
    • On-chip indexer supports up to 32 microsteps
    • Thermal and Short Circuit Protection
    • All Critical Control and Status Signals Brought Out to Test Headers
    • Includes a MSP430F1612 MCU for Signaling and Control
    DRV8825.pdf
    956.25 KB, 下载次数: 1
    Analog Signal Chain Guide.pdf
    5.86 MB, 下载次数: 0
    CPG004 DRV88xx Guide.pdf
    672.94 KB, 下载次数: 0
    GMT+8, 2025-1-15 21:46 , Processed in 0.107372 second(s), 16 queries , MemCache On.
