查看: 216|回复: 0
LMK00725EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-20 15:25:45 | 显示全部楼层 |阅读模式
    此评估模块(EVM)被设计来演示LMK00725设备的功能性和电气性能。为了获得最佳性能,该板配备了50欧姆的SMA连接器和50欧姆的阻抗受控的痕迹。DescriptionThe LMK00725 is a low skew, high performance clock fanout buffer, which distributes up to five 3.3V LVPECL outputs. The clocks are derived from one of two selectable inputs, which can accept differential or single-ended input signals.  This evaluation module (EVM) is designed to demonstrate the functionality and electrical performance of the LMK00725 device. For optimum performance, the board is equipped with 50-ohm SMA connectors and 50-ohm controlled impedance traces. Features
    • Easy to use evaluation board to fan-out up to 5 LVPECL clocks with low phase noise/jitter
    • Accepts differential or single-ended/LVCMOS input clock
    • Device control pins configurable through jumpers
    • Board power at 3.3-V for VCC
    LMK00725PW(R).pdf
    1001.24 KB, 下载次数: 0
    LMK00725EVM User Guide.pdf
    2.59 MB, 下载次数: 0
    GMT+8, 2025-1-15 20:49 , Processed in 0.130665 second(s), 16 queries , MemCache On.
