查看: 377|回复: 0
TSC2046开发套件
  • 签到天数: 361 天
    发表于 2014-3-20 15:13:39 | 显示全部楼层 |阅读模式
    TSC2046EVM-PDK是一套完整的评估套件,用于TSC2046EVM。该套件,其中包括一个基于USB的主板和评估软件,可与个人电脑使用,可用于完全评估TSC2046EVM。DescriptionThe TSC2046EVM-PDK is a complete evaluation kit for the TSC2046EVM. The kit, which includes a USB-based motherboard and evaluation software for use with a personal computer, can be used to completely evaluate the TSC2046EVM. The TSC2046EVM-PDK Motherboard (the USB_MOD Circuit Board) supplies power to power pin, J3, of the TSC2046EVM. Power for he motherboard is supplied either through its USB connection or from terminal blocks on the board.Features
    • Complete evaluation kit for the study of the TSC2046 touch screen controller
    • TSC2046EVM-PDK contains a USB connection to plug into the USB port on the PC
    • EVM will operate with multiple analog sources through on board terminal, J1.
    • The USB-MOD Circuit Board has an led (D1-D7) which lights when the power supplies are active
    TSC2046.pdf
    1.08 MB, 下载次数: 0
    TSC2046EVM/-PDK User Guide.pdf
    275.11 KB, 下载次数: 0
    GMT+8, 2025-1-15 20:43 , Processed in 0.119332 second(s), 16 queries , MemCache On.
