查看: 329|回复: 0
CDCEL949评估模块
  • 签到天数: 361 天
    发表于 2014-3-20 13:42:14 | 显示全部楼层 |阅读模式
    CDCEL949PERF-EVM将有助于验证CDCEL949与晶体的选项和1.8 V LVCMOS输入的功能和性能。输出可以通过SMA电缆连接到示波器直接。DescriptionThe CDCEL949PERF-EVM will help to verify the functionality and performance of CDCEL949 with the options of crystal and 1.8 V LVCMOS inputs. The outputs can be connected to the Oscilloscope directly with SMA cables. The below information/items are included: The EVM use's guide : SCAU022; the Programming Software Clock Pro: scac073d; CDCEL949 Datasheet: SCAS844; CDCE949 IBIS Model: SCAC094. Features
    • Easy-to-use evaluation module for fast prototyping and application evaluation.
    • Supporting the entire CDCE(L)949 family.
    • Easy and fast device programming through TI Pro-ClockT software. Evaluation of multiple crystals and reference clocks due to flexible input structure.
    • EVM completely USB powered in factory default.
    • Option for USB power and external power supply.
    CDCE949, CDCEL949.pdf
    958.18 KB, 下载次数: 0
    CDCE(L)9xx Performance EVM Guide.pdf
    1.31 MB, 下载次数: 0
    GMT+8, 2025-1-15 20:39 , Processed in 0.101970 second(s), 16 queries , MemCache On.
