查看: 293|回复: 0
SD034EVK评估模块
  • 签到天数: 361 天
    发表于 2014-3-19 16:23:35 | 显示全部楼层 |阅读模式
    SD034EVK评估模块可帮助设计人员评估LMH0034的SMPTE292M/259M自适应电缆均衡器的操作和性能。
    DescriptionThe Texas Instruments SD034EVK evaluation module helps designers evaluate the operation and performance of the LMH0034 SMPTE 292M / 259M Adaptive Cable Equalizer.The board accepts an input signal conforming to the SMPTE 292M or 259M standards via a 75Ω BNC input connector. The LMH0034 on the board will restore the input signal after it has been attenuated by coaxial cable. The LMH0034 differential output is provided via two 50Ω SMA connectors.Jumpers on the board can be configured for evaluation of LMH0034 features including the bypass mode, carrier detect, mute, and mute reference.
    LMH0034.pdf
    697.92 KB, 下载次数: 0
    GMT+8, 2025-1-15 21:00 , Processed in 0.118005 second(s), 16 queries , MemCache On.
