查看: 298|回复: 0
SM3320-BATT-EV参考设计
  • 签到天数: 361 天
    发表于 2014-3-19 16:00:23 | 显示全部楼层 |阅读模式
    SM3320-BATT-EV参考设计作用于充电控制器。该参考设计使用设备包括SM72295和SM72442。该SM72442 MPPT数字控制器和SM72295光伏全桥驱动器,设计用于控制高效率光伏应用中使用的DC/ DC转换。DescriptionThe SM72442 MPPT digital controller and SM72295 photovoltaic full bridge drivers are designed to control high efficiency DC/DC conversion used in photovoltaic applications. This application note will detail the usage of those devices in a battery charging application. The reference design is meant to provide support for a wide variety of implementations, however, unless otherwise noted, this reference design system is shown charging a 12V commercial automotive lead acid battery. If the battery voltage is very low, a slow charge current is applied and limited until the voltage rises above a pre-set threshold value Vt. The full charge current is then applied. Once full charge is detected on the voltage of the battery, the system switches to a floating charge and maintains the battery voltage at a fixed threshold. At any time, the system will run in MPPT mode if the available power is lower than the power required to achieve voltage or current regulation. Features
    • 12V Lead Acid Battery
    • Vin range = 15V to 45V Vmp (50V Voc)
    • Max Input Current: Isc = 11A
    • MPPT algorithm for optimized photovoltaic applications
    • Up to 9A charging current
    • Reverse current protection
    • Trickle charge and fast charge mode
    • Up to 98% converter efficiency
    • 14.2V max charge voltage, 13.5V floating voltage
    • Output voltage set-points can be re programmed
    SM72442.pdf
    777.85 KB, 下载次数: 1
    SM72295.pdf
    856.39 KB, 下载次数: 1
    SM3320-BATT-EV AppNote.pdf
    1.18 MB, 下载次数: 1
    GMT+8, 2025-1-15 20:46 , Processed in 0.113794 second(s), 16 queries , MemCache On.
