TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
TI BQ24030EVM是评估模块(EVM)为BQ24030单芯片充电和动态电源路径管理IC在3.5x4.5mm2 QFN封装。该EVM是一个完整的基于BQ24030电路和提供了一个方便的方法来评估IC的操作和性能。DescriptionThe Texas Instruments bq24030EVM is the evaluation module (EVM) for the bq24030 Single-Chip Charge and Dynamic Power-Path Management IC in 3.5x4.5mm2 QFN package. The EVM is a complete bq24030 based circuit and provides a convenient method to evaluate the operation and performance of the IC.The EVM development tool includes a tested evaluation module; a user guide (SLUU207) that contains the schematic, bill of materials, component placement, layout and the setup of the EVM; and the bq24030 data sheet.The performance of the EVM is optimized under a power supply of 5V typically. Charge current is limited to 2A. Features
- Typical input voltage: 5V
- Charge current limit: 2A
- Output regulation voltage: 4.2V
- OUT pin for AC conditions: regulated to 6V
