查看: 198|回复: 0
LMP91200评估板
  • 签到天数: 361 天
    发表于 2014-3-19 14:49:51 | 显示全部楼层 |阅读模式
    LMP91200评估板可以作为单独的或作为SensorAFE的eval平台(参见SensorAFE平台页面为软件和硬件的需要)的一部分。它允许通过3线SPI接口配置LMP91200和测试设备与真正的pH探头。此外,该评估板允许外部RTD的连接(例如电阻Pt100,Pt1000)输入。DescriptionThe LMP91200 evalboard (LMP91200EVAL) can be used as stand-alone or as part of SensorAFE eval platform (refer to the SensorAFE platform page for software and required hardware). It allows configuring the LMP91200 through a 3-wire SPI interface and testing the device with real PH probe. Moreover the eval board allows the connection of external RTD (for instance Pt100, Pt1000). FeaturesContents:
    • Assembled LMP91200EVAL Board
    • LMP91200 Userguide
    LMP91200.pdf
    1.08 MB, 下载次数: 0
    LMP91200 Eval Brd Guide.pdf
    558.84 KB, 下载次数: 0
    GMT+8, 2024-11-25 19:39 , Processed in 0.111916 second(s), 16 queries , MemCache On.
