查看: 314|回复: 0
BQ77PL900评估模块
  • 签到天数: 361 天
    发表于 2014-3-19 14:03:13 | 显示全部楼层 |阅读模式
    BQ77PL900EVM-001评估模块是用于BQ77PL900一个完整的评价体系,一个5至10节锂离子电池保护和AFE集成电路。该EVM包括1 BQ77PL900电路模块。DescriptionBQ77PL900EVM-001 evaluation module is a complete evaluation system for the bq77PL900, a five- to ten-cell Li-ion battery protection and AFE integrated circuit. The EVM includes one bq77PL900 circuit module. The circuit module includes one bq77PL900 integrated circuit (IC), sense resistor, power FETs and all other onboard components necessary to protect the cells from overcharge, over discharge, short circuit, and over current discharge in 5 to 10 series cell Li-ion or Li-polymer battery packs. The circuit module connects directly across the cells in a battery. With the EV2300 interface board and software, the user can read the bq77PL900 data registers, program the IC protection limits, and evaluate the overall functionality of the bq77PL900 solution under different operational conditions. An EV2300 board is required to interface this EVM with the PC and can be purchased separately. Features
    • Complete evaluation system for the bq77PL900 five to ten series cell lithium-ion or lithium-polymer battery protector and analog front end IC in stand-alone mode
    • Populated circuit module for quick setup
    • Connections for attaching a the circuit module to a host system
    BQ77PL900.pdf
    1.04 MB, 下载次数: 0
    BQ77PL900EVM-001.pdf
    1.02 MB, 下载次数: 0
    GMT+8, 2025-1-15 20:42 , Processed in 0.101247 second(s), 16 queries , MemCache On.
