查看: 317|回复: 0
TLV320AIC34评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-19 13:44:38 | 显示全部楼层 |阅读模式
    TLV320AIC34EVM有德州仪器的模块化EVM的外形,这使得设备性能和操作特性的直接评价,并简化了软件开发和系统原型。DescriptionThe TLV320AIC34EVM is in Texas Instruments‘ modular EVM form factor, which allows direct evaluation of the device performance and operating characteristics, and eases software development and system prototyping. This EVM is compatible with the 5 6K Interface Evaluation Module (SLAU104) and the HPA-MCUINTERFACE (SLAU106) from Texas Instruments and additional third-party boards whichsupports the TI Modular EVM format.The TLV320AIC34EVM-K is a complete evaluation/demonstration kit, which includes a USB-based motherboard called the USB-MODEVM Interface board and evaluation software for use with a personalcomputer running the Microsoft Windows operating systems.The USB connection from the PC provides power, control, and streaming audio data to the EVM for reduced setup and configuration. The EVM also allows external control signals, audio data, and power foradvanced operation, which allows prototyping and connection to the rest of the evaluation/development system. Features
    • Four Channel Audio DAC
    • 102&nbs;dBA Signal-to-Noise Ratio
    • 16/20/24/32 Bit Data
    • Supports Rates from 8 kHz to 96 kHz
    • 3D/Bass/Treble/EQ/De-Emphasis Effects
    • Flexible Power Saving Modes and Performance are available
    • Four Channel Audio ADC
    • 92 dBA Signal-to-Noise Ratio
    • Supports Rates From 8 kHz to 96 kHz
    • Digital Signal Processing and Noise
    • Filtering Available During Record
    • Twelve Audio Inputs
    • Programmable in Single-Ended or Fully Differential Configurations
    • 3-State Capability for Floating Input Configuration
    • Fourteen Audio Output Drivers
    • Stereo 8 Ω, 500 mW/Channel Speaker Drive Capability
    • Multiple Fully Differential or Single-Ended Headphone Drivers
    • Multiple Fully Differential or Single-Ended Line Outputs
    • Fully Differential Mono Outputs
    • Low Power: 15 mW Stereo 48 kHz Playback With 3.3 V Analog Supply
    • Ultralow-Power Mode With Passive Analog Bypass
    • Programmable Input/Output Analog Gains
    • Automatic Gain Control (AGC) for Record
    • Programmable Microphone Bias Level
    • Dual Programmable PLLs for Flexible ClockGeneration
    TLV320AIC34.pdf
    1.41 MB, 下载次数: 0
    TLV320AIC34EVM-K User Guide.pdf
    3.76 MB, 下载次数: 0
    GMT+8, 2025-1-15 21:03 , Processed in 0.108804 second(s), 16 queries , MemCache On.
