查看: 228|回复: 0
BQ3060EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 16:14:11 | 显示全部楼层 |阅读模式
    此评估模块(EVM)是为bq3060/bq29412电池管理系统的完整评估系统。该EVM包含一个bq3060/bq29412电路模块,PC机的USB连接线,以及基于Windows™的PC软件。DescriptionThis evaluation module (EVM) is a complete evaluation system for the bq3060/bq29412 battery management system. The EVM includes one bq3060/bq29412 circuit module, a PC USB cable, and Windows™-based PC software. The circuit module includes one bq3060 integrated circuit (IC), one bq29412 IC, and all other onboard components necessary to monitor and predict capacity, perform cell balancing, monitor critical parameters, protect the cells from overcharge, over-discharge, short-circuit, and overcurrent in 2-, 3- or 4-series cell Li-ion or Li-polymer battery packs. The circuit module connects directly across the cells in a battery. With the EV2300 interface board and software, the user can read the bq3060 data registers, program the chipset for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq3060/bq29412 solution under different charge and discharge conditions. Features
    • Complete evaluation system for the bq3060 SBS 1.1-compliant advanced gas gauge and bq29412 independent overvoltage protection IC
    • Populated circuit module for quick setup
    • PC software and interface board for easy evaluation
    • Software that allows data logging for system analysis
    BQ3060.pdf
    255.37 KB, 下载次数: 0
    BQ3060EVM-001 User Guide.pdf
    1.15 MB, 下载次数: 1
    GMT+8, 2025-1-15 20:38 , Processed in 0.113297 second(s), 16 queries , MemCache On.
