查看: 339|回复: 0
BQ24160EVM-721评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 16:03:42 | 显示全部楼层 |阅读模式
    该bq24160/161/163/168评估模块是用于评估紧凑,灵活,高效率,USB友好,开关模式充电管理单节锂离子电池,并在使用锂聚合物电池解决方案,一个完整的充电器模块广泛的便携式应用。DescriptionThe bq24160/161/163/168 evaluation module is a complete charger module for evaluating compact, flexible, high-efficiency, USB-friendly, switch-mode charge management solution for single-cell, Li-ion and Li-polymer batteries used in a wide range of portable applications. The bq24160/161/163/168 integrates a synchronous PWM controller, power MOSFETs, input-current sensing, high-accuracy current and voltage regulation, charge termination and power path management into a small WCSP packageFeatures
    • 153-mm × 153-mm × 1.2-mm footprint for entire solution
    • Input power connectors for both USB input and ac adapter
    • Programmable battery voltage, charge current, input current, and status via I2C™ interface
    • IN operating range of 4.2 V – 10 V (bq24160/161/163) or 4.2 V – 6 V (bq24168)
    • USB operating range of 4.2 V – 6 V
    • LED indication for status signals
    • Test points for key signals available for testing purposes. Easy probe hook-up
    BQ24160(A),61(B),63,68.pdf
    2.07 MB, 下载次数: 0
    BQ24160/1/3/8 EVM User Guide.pdf
    794.72 KB, 下载次数: 0
    GMT+8, 2025-1-15 21:07 , Processed in 0.124218 second(s), 16 queries , MemCache On.
