查看: 260|回复: 0
ADS1192演示套件
  • 签到天数: 361 天
    发表于 2014-3-18 15:38:35 | 显示全部楼层 |阅读模式
    ADS1x9xECG FE是一个演示套件的ADS1192和ADS1292,双通道,同步采样,16位或24位Δ-Σ(ΔΣ)模拟到数字转换器(ADC),带有一个内置的可编程增益放大器(PGA),内部参考,和一个板上振荡器。DescriptionThe ADS1x9xECG FE is a demonstration kit for the ADS1192 and ADS1292, a two channel, simultaneous sampling, 16-bit or 24-bit, delta-sigma(ΔΣ) analog-to-digital converter (ADC) with a built-in programmable gain amplifier (PGA), internal reference, and an on-board oscillator. The ADS1192 and ADS1292 chips incorporate all of the features that are commonly required in medical electrocardiogram (EKG/ECG) and electroencephalogram (EEG) applications. The ADS1x9xECG-FE is equipped with a MSP430F5529 micro-controller giving the user all the circuitry needed to run the ADC. The board can be used with a variety of patient simulators and allows the user to take advantage of the flexible input multiplexer which can be independently connected to the internally-generated signals for test, temperature, and lead-off detection. Software is available from Texas Instruments to allow the evaluation platform to run with a PC user interface. Features
    • Easy-to-use evaluation software for Microsoft™ Windows XP or Windows 7
    • Built-in analysis tools including oscilloscope, FFT, and histogram displays
    • Flexible input configurations
    • Digital Low Pass, High Pass, and 50/60Hz notch filters for post processing
    • Real time data streaming from the demo board to the PC
    • Ability to export data in simple test files for post processing
    ADS1191,92.pdf
    1.94 MB, 下载次数: 0
    ADS1x9xECG-FE User Guide.pdf
    4.03 MB, 下载次数: 1
    GMT+8, 2025-1-15 21:10 , Processed in 0.109615 second(s), 16 queries , MemCache On.
