查看: 452|回复: 0
BQ24150A评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 15:13:40 | 显示全部楼层 |阅读模式
    BQ24150A评估模块是用于评估紧凑,灵活,高效率,USB型开关模式充电管理单节锂离子电池,并在各种便携式应用中使用的锂聚合物电池解决方案,一个完整的充电器模块。DescriptionThe bq24150A evaluation module is a complete charger module for evaluating compact, flexible, high-efficiency, USB-friendly switch-mode charge management solution for single-cell Li-ion and Li-polymer batteries used in a wide range of portable applications. The bq2415x integrates a synchronous PWM controller, power MOSFETs, input current sensing, high-accuracy current and voltage regulation, and charge termination, into a small WCSP package. The charge parameters can be programmed through an I²C interface. Features
    • Evaluation Module For BQ24150A
    • High Efficiency Fully Integrated NMOS-NMOS Synchronous Buck Charger With 3 MHz Frequency
    • Integrated Power FETs for Up To 1.25 A Charge Rate
    • Programmable Battery Voltage, Charge Current, and Input Current via I²C Interface
    • Input Operating Range 4 V - 6 V
    • Boost Mode Operation for USB OTG
    • LED Indication for Status Signals
    • Test Points for Key Signals Available for Testing Purpose. Easy Probe Hook-up
    • Jumpers Available. Easy to Change Connections.
    BQ2415x YFF EVM.pdf
    426.51 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:21 , Processed in 0.109251 second(s), 16 queries , MemCache On.
