查看: 262|回复: 0
BQ24153AEVM-697评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 15:04:00 | 显示全部楼层 |阅读模式
    BQ24153AEVM-697评估模块是用于评估紧凑,灵活,高效率,USB友好,开关模式充电管理解决方案用于单节锂离子电池,并在广泛的便携使用锂聚合物电池一个完整的充电器模块应用程序。The BQ24153AEVM-697 evaluation module is a complete charger module for evaluating compact, flexible, high-efficiency, USB-friendly, switch-mode charge management solution for single-cell Li-ion and Li-polymer batteries used in a wide range of portable applications. The bq24153A integrates a synchronous PWM controller, power MOSFETs, input current sensing, high-accuracy current and voltage regulation, and charge termination, into a small WCSP package. The charge parameters can be programmed through an I2C interface Features
    • Evaluation module (EVM) for bq24153A
    • High-efficiency fully integrated NMOS-NMOS synchronous buck charger with 3-MHz frequency
    • Integrated power FETs for up to 1.55-A charge rate
    • Programmable battery voltage, charge current, and input current via I2C interface
    • Input operating range 4 V to 6 V
    • Boost-mode operation for USB OTG
    • LED indication for status signals
    • Test points for key signals available for testing purposes. Easy probe hook-up
    • Jumpers available. Easy-to-change connections
    BQ24153A/6A/8/9.pdf
    2.63 MB, 下载次数: 0
    BQ24153A/6A/7/8/9 User Guide.pdf
    825.88 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:42 , Processed in 0.118085 second(s), 16 queries , MemCache On.
