查看: 350|回复: 0
BQ27410EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 14:58:27 | 显示全部楼层 |阅读模式
    该bq27410EVM是一个完全组装和测试,用于评估bq27410单节电池电量计电路。该电路模块包含一个bq27410集成电路和必要的监测和预测的系统侧电量计解决方案能力的所有其它板载组件。DescriptionThe bq27410EVM is a fully assembled and tested circuit for evaluating the bq27410 single cell battery gas gauge. The circuit module includes one bq27410 integrated circuit and all other onboard components necessary to monitor and predict capacity for a system-side fuel gauge solution. The circuit module connects directly across the battery pack.If a designer wants to communicate with this EVM from a Windows-based PC, a separate USB Interface Adapter EVM is recommended. The EV2400 EVM interface board enables an IBM-compatible or other type PC (with the required driver for its particular platform) to communicate with the Texas Instruments SMBus, I2C, HDQ, or DQ interface gas gauges via a Universal Serial Bus (USB) port. With the EV2400 interface board and software, the user can read the bq27410 data registers, program the chipset for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq27410 solution under different charge and discharge conditions. The latest Windows™– based PC software can be downloaded from the product folder on the Texas Instruments Web site. Features
    • Complete evaluation system for the bq27410 gas gauge with Impedance Track technology
    • Populated circuit module for quick setup
    • Personal computer (PC) software and interface board for easy evaluation
    • Software that allows data logging for system analysis
    • Ability to upgrade to the latest firmware version by flash reprogramming
    BQ27410-G1.pdf
    1.01 MB, 下载次数: 0
    BQ27410EVM Guide.pdf
    18.92 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:35 , Processed in 0.112013 second(s), 16 queries , MemCache On.
