查看: 362|回复: 0
BQ20Z75EVM-001评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 14:18:26 | 显示全部楼层 |阅读模式
    BQ20Z75EVM-001评估模块充当对bq20z75/bq29412电池管理系统的完整评估系统。该EVM包括1 bq20z75/bq29412电路模块和一个电流检测电阻器,两个热敏电阻。DescriptionThis EVM is a complete evaluation system for the bq20z75/bq29412 battery management system. The EVM includes one bq20z75/bq29412 circuit module and a current sense resistor, two thermistors. The circuit module includes one bq20z75 IC, one bq29412 IC, and all other onboard components necessary to monitor and predict capacity, perform cell balancing, monitor critical parameters, protect the cells from overcharge, over discharge, short circuit, and overcurrent in 2-, 3- or 4-series cell Li-ion or Li-polymer battery packs. The circuit module connects directly across the cells in a battery. With the EV2300 interface board and software, the user can read the bq20z75 data registers, program the chipset for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq20z75/bq29412 solution under different charge and discharge conditions. An EV2300 board is required to interface this EVM with the PC and can be purchased separately.Kit Contains: bq20z75/bq29412 circuit moduleConnection cable to interface boardSet of support documentationFeatures
    • Complete evaluation system for the bq20z75 SBS 1.1-compliant advanced gas gauge with Impedance Track™ Technology bq29412 independent overvoltage protection IC
    • Populated circuit module for quick setup
    • Software that allows data logging for system analysis
    BQ20Z75 EVM-001.pdf
    2.22 MB, 下载次数: 0
    BQ29410-15, 19.pdf
    787.59 KB, 下载次数: 0
    BQ20Z75.pdf
    712.06 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:21 , Processed in 0.105656 second(s), 16 queries , MemCache On.
