查看: 825|回复: 0
ISO485EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 14:05:57 | 显示全部楼层 |阅读模式
    ISO485评估模块(EVM)支持RS-485数字隔离器的参数评估。该EVM将交付与安装在电路板上的ISO3082DW工厂。DescriptionThe ISO485 evaluation module (EVM) supports the parametric evaluation of RS-485 digital isolators. The EVM will be delivered with an ISO3082DW factory installed on the board. This EVM is intended to be used with the ISO15, ISO35 (SLOS580) and ISO3080, ISO3082, ISO3086 or ISO3088 (SLOS581). If another device is desired, please order samples from www.ti.com. If you do not have the capability to remove and install devices, and would like to have another device factory installed, please contact Technical Support at the link on this page. Note that this EVM is not intended for electromagnetic compatibility (EMC) tests.Features4000-VPEAK Isolation, 560-Vpeak VIORMUL 1577, IEC 60747-5-2 (VDE 0884, Rev 2Bus-Pin ESD Protection– 16 kV HBM Between Bus Pins and GND2– 6 kV HBM Between Bus Pins and GND11/8 Unit Load – Up to 256 Nodes on a BusMeets or Exceeds TIA/EIA RS-485 requirementsSignaling Rates up to 20 MbpsThermal Shutdown ProtectionLow Bus Capacitance – 16 pF (Typ)50 kV/µs Typical Transient ImmunityFail-safe Receiver for Bus Open, Short, Idle3.3-V Inputs are 5-V Tolerant
    ISO485.pdf
    135.17 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:38 , Processed in 0.107947 second(s), 16 queries , MemCache On.
