查看: 289|回复: 0
PGA2505评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 14:00:09 | 显示全部楼层 |阅读模式
    PGA2505EVM提供了评价PGA2505的性能和功能一个方便的平台。DescriptionThe PGA2505EVM is a convenient platform for evaluating the performance and features of the PGA2505. The PGA2505 is a digitally-controlled, microphone preamplifier designed for amplifying the output of dynamic and condenser microphones and driving high-performance audio analog-to-digital (A/D) converters. Features
    • Accepts either XLR- or TRS-balanced input connections
    • ?Configurable front-end circuit options for prototyping pads and filters
    • XLR-balanced output with flexible output loading options
    • Buffered PC parallel and DATA_IN ports provide host interface connections
    • DATA_OUT port allows daisy-chaining of multiple PGA2505EVM boards
    • Register readback function supports host interface diagnostic capability
    • LED indicators for GPOs and the over-range output (OVR)
    • Common-mode voltage input (VCOMIN) terminal
    • ?Includes applications software that is compatible with most personal computers with a built-in parallel port and equipped with Microsoft Windows 9x, 2000, or XP operating systems
    • Requires +5V and –5V analog supplies, as well as a +5V digital supply
    PGA2505.pdf
    386.48 KB, 下载次数: 0
    PGA2505EVM.pdf
    881.91 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:43 , Processed in 0.116000 second(s), 16 queries , MemCache On.
