查看: 263|回复: 0
BQ24620EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 13:53:24 | 显示全部楼层 |阅读模式
    评估模块bq24600/bq24620/bq24640 。该bq24600是高度集成的锂离子或锂聚合物开关模式电池充电控制器。Evaluation Module for bq24600/bq24620/bq24640. the bq24600 is a highly integrated Li-ion or Li-polymer switch-mode battery charge controller. The bq24620 is highly integrated switch-mode battery charge controller designed specifically to charge Lithium Phosphate battery chemistries. The bq24640 is highly integrated super capacitor switch-mode charge controller. The devices offer a constant-frequency synchronous PWM controller with high accuracy charge current and voltage regulation, adapter current regulation, termination, charge preconditioning, and charge status monitoring, The bq24600/bq24620 charges the battery in three phases: preconditioning, constant current, and constant voltage. Charge is terminated when the current reaches a minimum user-selectable level. A programmable charge timer provides a safety backup for charge termination. The bq24600/bq24620 automatically restarts the charge cycle if the battery voltage falls below an internal threshold, and enters a low-quiescent current sleep mode when the input voltage falls below the battery voltage. Features
    • Evaluation Module for bq24600/bq24620/bq24640
    • High Efficiency Synchronous Buck Charger
    • User-programmable up to 26V Battery Voltage
    • AC Adapter Operating Range 5V to 28V
    • LED Indication for Control and Status Signals
    • Test Points for Key Signals Available for Testing Purpose. Easy Probe Hook-up.
    • Jumpers Available. Easy to Change Connections
    BQ24620.pdf
    1.97 MB, 下载次数: 0
    BQ24600,20,40 User Guide.pdf
    997.41 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:19 , Processed in 0.111665 second(s), 16 queries , MemCache On.
