查看: 363|回复: 0
PGA2500评估模块
  • 签到天数: 361 天
    发表于 2014-3-18 13:31:04 | 显示全部楼层 |阅读模式
    PGA2500EVM提供了评估PGA2500产品的性能和功能一个方便的平台。数据输出端口可以被用于以菊花链的多个PGA2500EVM电路板。该EVM需要使用三个电源,+/ -5模拟电源和+5数字供电的。DescriptionThe PGA2500EVM provides a convenient platform for evaluating the performance and features of the PGA2500 product. Data output ports can be used to daisy-chain multiple PGA2500EVM circuit boards. The EVM requires the use of three power supplies, +/-5 analog supply and a +5 digital supply. Features
    • Accepts either XLR or TRS balanced input connections
    • Configurable front-end circuit options for prototyping pads and filters
    • SLR balanced output with flexible output loading options
    • Buffered PC parallel and DATA_IN ports provide host interface connections
    • DATA_OUT port allows daisy-chaining of multiple PGA2500EVM boards
    • Register read back function supports host interface diagnostic capability
    • LED indicators for GPOs and the over range output
    • Common mode voltage input (VcomIN) terminal
    • Includes applications software which is compatible with most personal computers that have a built-in parallel port and run Microsoft Windows 9x, 2000, or XP operating systems
    PGA2500.pdf
    382.35 KB, 下载次数: 0
    PGA2500EVM User Guide.pdf
    261.21 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:24 , Processed in 0.126344 second(s), 16 queries , MemCache On.
