查看: 894|回复: 0
TLK110评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 15:18:49 | 显示全部楼层 |阅读模式
    TLK110CUSEVM提供了一个平台,使用户能够轻松地评估,包含TLK110设备的设计和市场体系。DescriptionThe TLK110CUSEVM provides a platform that allows the users to easily evaluate, design and market systems containing the TLK110 device. Features
    • Industrial temperatures (-40°C to 85°C)
    • Industrial temperature external magnetics
    • Control and status:
    ---Configurable 8 PHY Addresses – 01h (default) or any other address between 00h - 07h using jumpers---8 LEDs – 2 power, 6 status LEDs (speed, link, and active data)Strap options:-MII/RMII jumper (MII disable)-Resistor / Jumper strapping options:
    • Configurable PHY addresses 08h - 31h
    • CFG_ANEG_MODE
    • CFG_ANAEG_SPD_0 ,1
    • CFG_CROSSOVER
    -RESET _N jumper
    • Connections for the following interfaces:
    ---MII connector---RJ-45 connector
    • Single sided component placement
    • On-board clock – crystal/oscillator dual footprint
    • On-board power supplied by MII connector only, resistors to configure 5V or 3.3V operation
    TLK110.pdf
    1.43 MB, 下载次数: 0
    TLK110 EVM User Guide.pdf
    765.19 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:48 , Processed in 0.128519 second(s), 16 queries , MemCache On.
