查看: 266|回复: 0
BQ20Z95EVM-001评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 15:02:42 | 显示全部楼层 |阅读模式
    此评估模块(EVM)是为bq20z95/bq29412电池管理系统的完整评估系统。该EVM包括1 bq20z95/bq29412电路模块。DescriptionThis evaluation module (EVM) is a complete evaluation system for the bq20z95/bq29412 battery management system. The EVM includes one bq20z95/bq29412 circuit module. The circuit module includes one bq20z95 integrated circuit (IC), one bq29412 IC, and all other onboard components necessary to monitor and predict capacity, perform cell balancing, monitor critical parameters, protect the cells from overcharge, over-discharge, short-circuit, and overcurrent in 2-, 3- or 4-series cell Li-ion or Li-polymer battery packs. The circuit module connects directly across the cells in a battery.With the EV2300 interface board and software, the user can read the bq20z95 data registers, program the chipset for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq20z95/bq29412 solution under different charge and discharge conditions. An EV2300 board is required to interface this EVM with the PC and can be purchased separately.Kit Contains:
    • bq20z95/bq29412 circuit module
    • Connection cable to interface board
    • Set of support documentation
    Features
    • Complete evaluation system for the bq20z95 SBS 1.1-compliant advanced gas gauge with Impedance Track™ technology and bq29412 independent overvoltage protection IC
    • Populated circuit module for quick setup
    • Software that allows data logging for system analysis
    BQ20Z95.pdf
    596.33 KB, 下载次数: 0
    BQ29410-15, 19.pdf
    787.59 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:43 , Processed in 0.128384 second(s), 16 queries , MemCache On.
