查看: 234|回复: 0
BQ24650评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 14:44:49 | 显示全部楼层 |阅读模式
    BQ24650EVM评估模块帮助用户评估BQ24650同步电池充电器。该BQ24650是一个高度集成的开关模式电池充电控制器。它提供的输入电压调节,从而降低了充电电流,当输入电压低于设定水平。The BQ24650EVM Evaluation Module assists users in evaluating the bq24650 synchronous battery charger. The bq24650 is a highly integrated switch-mode battery charge controller. It provides input voltage regulation, which reduces charge current when input voltage falls below a programmed level. When the input is powered by a solar panel, the input regulation loop maintains the panel at maximum power output. The BQ24650EVM is also called the HPA639 A. The manual includes the bq24650EVM bill of materials, board layout, and schematic. The user's guide SLUU444 describes the features and operation of the bq24650EVM.Features
    • Synchronous switch-mode battery charge controller for solar power
    • Resistor-programmable up to 26-V battery voltage
    • Input operating range: 5V to 28V
    • LED indication for charge status
    • Test points for key signals available for testing purposes; easy probe hook-up.
    • Jumpers available; easy-to-change setting
    BQ24650.pdf
    2.8 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:40 , Processed in 0.118806 second(s), 16 queries , MemCache On.
