查看: 207|回复: 0
DRV8662评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 14:39:02 | 显示全部楼层 |阅读模式
    DRV8662EVM评估模块(EVM)是一个全差分,高压压电致动器的驱动程序,提供快速的响应时间为单层和多层压电致动器。该评估模块包含DRV8662压电式触觉驱动器,可编程MSP430和无源器件的完整评估。DescriptionThe DRV8662EVM Evaluation Module (EVM) is a fully-differential, high-voltage piezo actuator driver that provides quick response time for single layer and multi-layer piezo actuators. The DRV8662 drives piezo loads up to 200V differentially using an adjustable integrated boost converter. The evaluation module contains the DRV8662 piezo haptics driver, a programmable MSP430, and passive components for complete evaluation. Features
    • High-Voltage Piezo Haptic Driver
    • Drives single-layer and multi-layer piezo actuators
    • Adjustable 200V Differential Output
    • A programmable MSP430 with sample waveforms
    • Directly connect external PWM and analog signals
    • Fast Start-up Time of 1.5ms
    • Wide Supply Voltage Range of 3.0V to 5.5V
    • 1.8V Compatible Digital Pins
    • Thermal Protection
    • Available in a 4mm x 4mm x 0.9 mm QFN package (RGP)
    DRV8662.pdf
    1.07 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:47 , Processed in 0.103325 second(s), 16 queries , MemCache On.
