查看: 256|回复: 0
BQ24133EVM-715-5V评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 14:27:00 | 显示全部楼层 |阅读模式
    BQ24133EVM-715-5V(-001)协助用户评估BQ24133同步电池充电器。该BQ24133是高度集成的独立锂离子和锂聚合物开关模式电池充电控制器,具有两个集成的N沟道功率MOSFET和功率路径选择器闸极驱动器。The BQ24133EVM-715-5V (-001) assists users in evaluating the bq24133 synchronous battery charger. The bq24133 is highly integrated stand-alone Li-ion and Li-polymer switch-mode battery charge controllers with two integrated N-channel power MOSFETs and power path selector gate driver. It offers a constant-frequency synchronous PWM controller with high accuracy regulation of input current, charge current and voltage. It also provides battery detection, pre-conditioning, charge termination, and charge status monitoring. The EVM is also called the HPA715 (-001). This EVM is optimized for a 5V input voltage and charges a single cell 4.2V Li-ion battery. The UG manual includes the bq24133EVM bill of materials, board layout, and schematic. Features
    • Evaluation module for bq24133
    • Stand-alone synchronous switch-mode, battery-charge controller
    • Integrated N-MOSFETs and power path selector
    • Input operating range: 4.5 V to 8 V
    • LED indication for charge status
    • Test points for key signals available for testing purposes; easy probe hook-up
    • Jumpers available; easy-to-change setting
    BQ24133.pdf
    2.54 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:27 , Processed in 0.109753 second(s), 16 queries , MemCache On.
