查看: 296|回复: 0
BQ27501EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 14:01:02 | 显示全部楼层 |阅读模式
    此评估模块(EVM)是为bq2750x一个完整的评价体系。该EVM包括1 bq2750x电路模块,一个电流检测电阻器,和一个热敏电阻。DescriptionThis evaluation module (EVM) is a complete evaluation system for the bq2750x. The EVM includes one bq2750x circuit module, a current sense resistor, and one thermistor. The circuit module includes one bq27500 or bq27501 integrated circuit (IC), one TPS71525 IC, and all other onboard components necessary to monitor and predict capacity for a system side fuel gauge solution. The circuit module connects directly across the battery pack. With the EV2300 interface board and software, the user can read the bq2750x data registers, program the chipset for different pack configurations, log cycling data for further evaluation, and evaluate the overall functionality of the bq2750x solution under different charge and discharge conditions. An EV2300 board is required to interface this EVM with the PC and can be purchased separately.Features
    • Complete evaluation system for the bq2750x gas gauge with Impedance Track™ Technology
    • Populated circuit module for quick setup
    • Software that allows data logging for system analysis
    BQ27501.pdf
    1021.63 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:29 , Processed in 0.121820 second(s), 16 queries , MemCache On.
