查看: 324|回复: 0
BQ24041EVM评估模块
  • 签到天数: 361 天
    发表于 2014-3-17 13:52:13 | 显示全部楼层 |阅读模式
    BQ2404x系列器件是高度集成的面向空间有限的便携式应用的锂离子电池线性充电器设备。该设备无论是从USB端口或AC适配器进行操作。该bq2404x有一个单一的输出功率为电池充电。The bq2404x series of devices are highly integrated Li-ion linear charger devices targeted at space-limited portable applications. The devices operate from either a USB port or AC adapter. The bq2404x has a single power output that charges the battery. A system load can be placed in parallel with the battery as long as the average system load does not keep the battery from charging fully during the 10 hour safety timer. The battery is charged in three phases: conditioning, constant current, and constant voltage. In all charge phases, an internal control loop monitors the IC junction temperature and reduces the charge current if an internal temperature threshold is exceeded. The charger power stage and charge current sense functions are fully integrated. The charger function has high-accuracy current and voltage regulation loops, charge status display, and charge termination. The pre-charge current and termination current threshold are programmed via an external resistor on the bq24040. The fast charge current value is also programmable via an external resistor.
    GMT+8, 2025-1-15 23:29 , Processed in 0.104571 second(s), 15 queries , MemCache On.
