查看: 314|回复: 0
TAS3208EVM-LC评估套件
  • 签到天数: 361 天
    发表于 2014-3-14 16:33:19 | 显示全部楼层 |阅读模式
    TAS3208EVM-LC包含硬件逻辑,它可以被用来重置TAS3208数字音频处理器,无需断开并重新枚举USB控制器。The TAS3208EVM-LC contains hardware logic, which can be utilized to reset the TAS3208 Digital Audio Processor without disconnecting and re-enumerating the USB Controller. A red LED indicates the period in which the reset is active. Additional on-board LEDs indicate that the board is powered, Active I2C transactions from either a host controller or the EEPROM, and that the USB link to the host PC is established.
    TAS3208.pdf
    976.84 KB, 下载次数: 0
    TAS3208-LC Guide.pdf
    399.88 KB, 下载次数: 0
    TAS3208EVM-LC Important - Read Me First.pdf
    148.67 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:45 , Processed in 0.113346 second(s), 16 queries , MemCache On.
