查看: 301|回复: 0
BQ27210EVM估模块
  • 签到天数: 361 天
    发表于 2014-3-14 16:17:57 | 显示全部楼层 |阅读模式
    BQ27x10EVM包括一个bq27x10EVM电路模块。该电路模块包含一个bq27x10,一个电流检测电阻,并板载需要计算剩余电池容量和预测系统的运行时间来清空所有其他组件。DescriptionThe bq27x10EVM includes one bq27x10EVM circuit module. The circuit module includes one bq27x10, a current sense resistor, and all other components onboard necessary to calculate remaining battery capacity and predict system run-time to empty. The circuit module connects directly across the cell in a battery. With the PC interface board and software, the user can read the bq27x10 data registers, program the on-chip configuration EEPROM, and evaluate the functions of the bq27x10 under different charge and discharge conditions. An EV2300 board is required to interface this EVM with the PC and can be purchased separately. Features
    • Complete evaluation system for the bq27x10 battery gas gauge
    • Populated circuit module for quick setup
    • PC software and interface board for easy evaluation
    • Software allows EEPROM programming and data logging for system analysis
    BQ27010,210.pdf
    1.01 MB, 下载次数: 0
    BQ27x10EVM.pdf
    832.22 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:36 , Processed in 0.113293 second(s), 15 queries , MemCache On.
