查看: 288|回复: 0
ADS7845EVM-PDK评估模块
  • 签到天数: 361 天
    发表于 2014-3-14 13:36:52 | 显示全部楼层 |阅读模式
    ADS7845EVM-PDK是一套完整的评估套件,用于ADS7845EVM。该套件,其中包括一个基于USB的主板和评估软件,可与个人电脑使用,可用于完全评估ADS7845EVM。The ADS7845EVM-PDK is a complete evaluation kit for the ADS7845EVM. The kit, which includes a USB-based motherboard and evaluation software for use with a personal computer, can be used to completely evaluate the ADS7845EVM. The ADS7845EVM-PDK Motherboard (the USB_MOD Circuit Board) supplies power to power pin, J3, of the ADS7845EVM. Power for the motherboard is supplied either through its USB connection or from terminal blocks on the board.Features
    • Complete evaluation kit for the study of the ADS7845EVM
    • ADS7845EVM-PDK contains a USB connection to plug into the USB port on the PC
    • EVM will operate with multiple analog sources through on board terminal, J1
    • An external reference voltage can be supplied through terminal J1 pin 20
    • LEDs on the USB-MOD Circuit Board indicate system power
    ADS7845.pdf
    318.08 KB, 下载次数: 0
    ADS7845EVM/-PDK Guide.pdf
    386.59 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:23 , Processed in 0.120431 second(s), 16 queries , MemCache On.
