TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
BQ26231EVM-001是BQ26231基于FLASH的电池监视IC的完整评估系统。该EVM包含一个BQ26231的电路模块,EV2200 PC接口板的电量监测计评估,PC串行电缆和基于Windows的PC软件。DescriptionThe bq26231EVM-001 is a complete evaluation system for the bq26231 FLASH based Battery Monitoring IC. The EVM includes one bq26231 circuit module, an EV2200 PC Interface Board for Gas Gauge Evaluation, a PC serial cable, and Windows-based PC software.The circuit module includes the bq26231 IC and all other components on-board necessary to monitor capacity and other critical parameters in a one-cell Li-Ion battery pack or a battery pack of any chemistry with a voltage of 2.8 to 5.5 V.The circuit module connects directly across the cell(s) in the battery. With the EV2200 interface board and software, the user can read the bq26231 data registers and evaluate the functions of the bq26231 under different charge and discharge conditions.Specifications: Input voltage BAT+/BAT-: 2.8-5.5VCharge and discharge current: 4A(max)Features
- Complete evaluation system for the bq26231 battery monitor IC
- Populated circuit module for quick setup
- PC software and interface board for easy evaluation
- Software that allows data-logging for system analysis
