查看: 309|回复: 0
LM25066EVK评估套件
  • 签到天数: 361 天
    发表于 2014-3-13 15:22:58 | 显示全部楼层 |阅读模式
    LM25066EVK评估套件为设计工程师提供一个功能完善,智能监控和热插拔保护电路板的正电压系统。The LM25066EVK evaluation kit provides the design engineer with a fully functional, intelligent monitoring and hot-swap protection board designed for positive voltage systems. This application note describes the various functions of the evaluation board, how to test and evaluate it, and how to use the companion GUI.The GUI is used to collect telemetry, configure warning and fault thresholds, and assist the designer with selection of the external components for a specific application. Use of the advanced telemetry and monitoring capabilities of the LM25066 requires external control via the Power Management Bus (PMBus) interface. However, the LM25066 is capable of acting as a hot-swap and protection circuit without any PMBus intervention. Please check the LM25066 System Power Management & Protection IC with PMBus (SNVS654) data sheet for the latest software and data sheet information.
    LM25066 Eval Brd Guide.pdf
    4.75 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:19 , Processed in 0.119340 second(s), 16 queries , MemCache On.
