查看: 1406|回复: 0
BQ24075电源评估模块
  • 签到天数: 361 天
    发表于 2014-3-13 14:47:11 | 显示全部楼层 |阅读模式
    BQ24075评估模块提供用于评估使用bq24072/3/4/5/9(T)和bq24230/ 2产品系列的便携式应用的充电管理和系统电源解决方案的性能的简便方法。This user’s guide describes the bq24072/3/4/5/9(T) and bq24230/2 (bqTiny-III™) evaluation module (EVM). The EVM provides a convenient method for evaluating the performance of a charge management and system power solution for portable applications using the bq24072/3/4/5/9(T) and bq24230/2 product families. A completely designed and tested module is presented. The charger is designed to deliver up to 1.5 A of continuous current to the system or charger for one-cell Li-ion or Li-polymer applications (see the data sheet for correct device) using a dc power supply. The charger is programmed from the factory to deliver 0.9 A of charging current. This EVM was designed as a stand-alone evaluation module, but it also can be interfaced with the system and host via the connectors and headers.
    BQ24072-75.pdf
    2.66 MB, 下载次数: 0
    BQ24072-75/9, BQ24230/2 EVM Guide.pdf
    373.34 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:18 , Processed in 0.126365 second(s), 16 queries , MemCache On.
