查看: 213|回复: 0
BQ27010评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-13 13:59:00 | 显示全部楼层 |阅读模式
    BQ27010评估模块(EVM)是为bq27x10单节锂离子和锂聚合物电池电量监测计器的完整评估系统。该BQ27010EVM包括一个BQ27010EVM电路模块。DescriptionThe BQ27010EVM is a complete evaluation system for the bq27x10 single-cell Li-ion and Li-polymer battery gas gauge device. The BQ27010EVM includes one BQ27010EVM circuit module. The circuit module includes one bq27x10, a current sense resistor, and all other components on board necessary to calculate remaining battery capacity and predict system run-time to empty. The circuit module connects directly across the cell in a battery. An EV2300 board is required to interface this EVM with the PC and can be purchased separately. Kit Contains:BQ27010EVM circuit module with sense resistorSet of support documentationFeatures
    • Complete evaluation system for the bq27x10 battery gas gauge
    • Populated circuit module for quick setup
    • Software allows EEPROM programming and data logging for system analysis
    BQ27010,210.pdf
    1.01 MB, 下载次数: 0
    BQ27x10EVM.pdf
    832.22 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:22 , Processed in 0.116018 second(s), 16 queries , MemCache On.
