查看: 265|回复: 0
UCC39002评估模块
  • 签到天数: 361 天
    发表于 2014-3-13 13:51:28 | 显示全部楼层 |阅读模式
    UCC39002是一种先进的,高性能的负载共享控制器,提供所有必要的功能,以并联多个独立的电源或直流 - 直流模块。DescriptionThe UCC39002 is an advanced, high-performance load-share controller that provides all the necessary functions to parallel multiple independent power supplies or dc-to-dc modules. This load-share circuit is based upon the automatic master/slave architecture utilized in the UC3902 and UC3907 load-share controllers providing better than 1% current-share error between the modules at full load. Features
    • High accuracy, better than 1% current share error at full load
    • High-side current sensing
    • Ultra-low offset current sense amplifier
    • Single wire load-share bus
    • Intel® SSI load-share spcification compliant
    • Disconnect from load-share bus at stand-by
    • Load-share bus protection against shorts to GND or to the supply rail
    • 8-pin MSOP package option minimizes board space
    • External or internal bias selection
    • External shutdown switch for each module
    UCC39002 Guide.pdf
    461.08 KB, 下载次数: 0
    UCC29002, UCC29002/1, UCC39002.pdf
    1.03 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:44 , Processed in 0.110838 second(s), 16 queries , MemCache On.
