查看: 249|回复: 0
TUSB3410UARTPDK评估模块
  • 签到天数: 361 天
    发表于 2014-3-13 13:31:38 | 显示全部楼层 |阅读模式
    TUSB3410UARTPDK评估模块可以用来评估TUSB3410的USB到串口转换器(或“桥梁”。),方便用户将熟悉的USB认证要求。The TUSB3410UARTPDK can be used to evaluate the TUSB3410 as a USB to Serial converter (or "bridge.") The user is expected to be familiar with USB certification requirements. For more information on Universal Serial Bus and certification, logo, and testing requirements, see www.usb.org.An object code version of the Windows XP, Windows Vista and Windows 7 Virtual COM Port (VCP) Software (Drivers and Firmware) can be downloaded from the TUSBWINVCP Tool Folder.A Linux version of the VCP Software is also available from Brimson Labs in the Third-party Tool Folder TUSB-3P-LNXVCP.The I²C Header Generator Utility (see below for download) is a DOS-based tool that generates an image file for your I²C EEPROM, using your binary object code and/or custom descriptors as inputs.The AppLoader Utility should not be used with the UART tool.Additional items needed for EVM use include utilities for monitoring USB traffic, an EEPROM (for storing your unique VID/PID necessary for certification and logo use). See www.usb.org for more information), and a USB-enabled host. Features
    • Quickly convert an RS-232 product to USB
    • Jump start development or use as a complete USB-to-Serial converter
    • Firmware, VCP drivers, and schematics provided
    • Quick connect to a USB-enabled host
    • No Power Supply required - the EVM gets power via the included USB cable.
    TUSB3410UARTPDK User Guide.pdf
    248.63 KB, 下载次数: 0
    TUSB3410UARTPDK Schematic.pdf
    45.52 KB, 下载次数: 0
    TUSB3410, TUSB3410I Data Manual.pdf
    1.48 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:41 , Processed in 0.121594 second(s), 16 queries , MemCache On.
