查看: 287|回复: 0
BQ2013H评估板
  • 签到天数: 361 天
    发表于 2014-3-13 13:25:17 | 显示全部楼层 |阅读模式
    BQ2013HEVM-001是为BQ2013H气体计IC,用于高放电率的完整评估系统。该EVM包含一个DM2013H电路模块,一个电流检测电阻,EV2200 PC接口板的气体监测评估,一个PC串行电缆和基于Windows的PC软件。The bq2013HEVM-001 is a complete evaluation system for the bq2013H Gas-Gauge IC for High Discharge Rates. The EVM includes one DM2013H circuit module, a current sense resistor, an EV2200 PC Interface Board for Gas-Gauge Evaluation, a PC serial cable, and Windows-based PC software. The DM2013H ciruit module includes one bq2013H IC, 5 LEDs to display remaining capacity, and all other components on-board necessary to monitor capacity and other critical parameters in NiCd, NiMH, or lead-acid-based battery packs. The DM2013H connects directly across the cells in a battery. With the EV2200 interface board and software, the user can read the bq2013H data registers and evaluate the functions of the bq2013H under different charge and discharge conditions.
    BQ2013H.pdf
    536.41 KB, 下载次数: 0
    BQ2013HEVM-001.pdf
    191.49 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:36 , Processed in 0.107798 second(s), 16 queries , MemCache On.
