查看: 500|回复: 0
HD3SS6126评估模块(EVM)板
  • 签到天数: 361 天
    发表于 2014-3-13 13:14:30 | 显示全部楼层 |阅读模式
    HD3SS6126评估模块(EVM)板为两个USB主机系统之一,它们之间进行选择USB设备和两个USB主机之间切换。Use the HD3SS6126 evaluation module (EVM) board to select between one of two USB host systems for an USB device and to switch between two USB hosts. Figure 1 shows the KVM switch application. The bidirectional capability of the HD3SS6126 also supports applications that allow connections between two target devices and one source device, such as a shared USB 3.0 host between two USB 3.0 devices.
    HD3SS6126RUAR.pdf
    810.23 KB, 下载次数: 1
    HD3SS6126EVM User Guide.pdf
    669.33 KB, 下载次数: 1
    GMT+8, 2025-1-15 23:36 , Processed in 0.113923 second(s), 16 queries , MemCache On.
