查看: 329|回复: 0
LM5064EVK评估模块
  • 签到天数: 361 天
    发表于 2014-3-13 11:07:27 | 显示全部楼层 |阅读模式
    LM5064EVK评估模块为电源设计工程师提供一个功能完善的智能监控和保护控制器电路板设计的负电压系统。The LM5064EVK evaluation module provides the power design engineer with a fully functional intelligent monitoring and protection controller board designed for negative voltage systems. This application note describes the various functions of the board, how to test and evaluate it, and how to use the GUI design tool to change the components for a specific application. Use of the advanced telemetry and monitoring capabilities of this device requires the installation of the Intelligent Power Manager GUI; however, the LM5064 is capable of acting as a hot-swap and protection circuit without any software installation. Please check the LM5064 Negative Voltage System Pwr Mgmt & Protection IC with PMBus (SNVS718) for the latest software and data sheet information.
    LM5064.pdf
    1.34 MB, 下载次数: 0
    LM5064 Eval Kit Appl Note.pdf
    10.05 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:37 , Processed in 0.115218 second(s), 16 queries , MemCache On.
