查看: 255|回复: 0
TPS24750评估模块(EVM)
  • 签到天数: 361 天
    发表于 2014-3-12 16:41:09 | 显示全部楼层 |阅读模式
    TPS24750EVM-546功能与集成MOSFET内置SOA保护一个高度复杂的热插拔控制器。该EVM为用户提供了对设备进行全面评估便捷的测试点,连接器和各项指标。 TPS24751将自动重试,而TPS24750将系统故障后锁存。DescriptionTPS24750EVM-546 features a highly sophisticated hot swap controller with integrated MOSFET with built in SOA protection. The EVM provides the user with convenient test points, connectors, and various indicators for full evaluation of the device. TPS24751 will automatically retry while TPS24750 will latch after a system fault.  Features
    • 10A integrated MOSFET hot swap controllers with either automatic retry (TPS24751) or latched fault (TPS24750) versions.
    • 35A input/output screw type terminals.
    • Onboard fault and power good LED’s.
    • Linear output ramp (gate dV/dt control) option using jumper.
    • On board test point access for all device level pins.
    TPS2475xEVM-546 User Guide.pdf
    353.22 KB, 下载次数: 0
    TPS24750/51.pdf
    1.97 MB, 下载次数: 0
    GMT+8, 2025-1-15 23:43 , Processed in 0.115764 second(s), 16 queries , MemCache On.
