查看: 398|回复: 0
LMH1981评估板
  • 签到天数: 361 天
    发表于 2014-3-12 16:18:31 | 显示全部楼层 |阅读模式
    LMH1981评估板可用于评估LMH1981多格式同步分离器,也可以用于设计印刷电路板布局的参考。The LMH1981 evaluation board can be used to evaluate the LMH1981 multi-format sync separator and as a reference for designing the PCB layout. For more information on PCB layout considerations, see the LMH1981 Multi-Format Video Sync Separator Data Sheet (SNLS214).The board should be powered with a clean supply voltage of 3.3 V to 5.0 V using the banana jacks VCC (J2) and GND (J3). The supply should be well-regulated within ±5% variation of the voltage range and should not be shared directly with other digital circuitry.
    LMH1981.pdf
    1.23 MB, 下载次数: 0
    LMH1981 Eval Brd Guide.pdf
    800.13 KB, 下载次数: 0
    GMT+8, 2025-1-15 23:29 , Processed in 0.113516 second(s), 16 queries , MemCache On.
