查看: 315|回复: 0
ADS1293评估模块
  • 签到天数: 361 天
    发表于 2014-3-12 14:26:51 | 显示全部楼层 |阅读模式
    ADS1293评估模块是一个基于ADS1293的演示套件,三通道,24位Δ-Σ(ΔΣ)模拟到数字转换器(ADC),内部参考和板载振荡器。该ADS1293芯片集成了所有,通常在医疗心电图(EKG/ ECG)中应用。DescriptionThe ADS1293EVM is a demonstration kit for the ADS1293, a three channel, 24-bit delta-sigma (ΔΣ) analog-to-digital converter (ADC), internal reference, and an on-board oscillator. The ADS1293 chip incorporates all of the features that are commonly required in medical electrocardiogram (EKG/ECG)applications. The ADS1293EVM is equipped with a MSP430F5529 micro-controller giving the user all the circuitry needed to run the ADC. The board can be used with a variety of patient simulators and allows the user to take advantage of the flexible input multiplexer which can be independently connected to the internally-generated signals for test and lead-off detection. Software is available from Texas Instruments to allow the evaluation platform to run with a PC user interface. Features
    • Easy to use online and offline WEBENCH Medical AFE Designer tool
    • Clickable block diagram in tool
    • Pre-programmed 3-lead and 5-lead ECG application
    • Easy-to-use evaluation software for Microsoft™ Windows XP or Windows 7
    • Built-in analysis tools including oscilloscope and histogram displays, estimated device and measured system performances, and beats per minute calculation
    • Real time data streaming from the demo board to the PC
    • Ability to export data in simple test files for post processing
    GMT+8, 2025-1-15 23:29 , Processed in 0.115582 second(s), 15 queries , MemCache On.
